synjin
So, I was looking to make a tandem wing airplane and found a trail of information leading to Maurice Delanne who designed the Arsenal-Delanne 10-C2...which led to...well, you know, internet rabbit holes.
Anyway, I set out to build a Delanne tandem wing-esque plane. Started with the wing from the Bloody P-40 and designed around that (it's an easy to build wing and a solid flier). Mk.I glide tested well, but was crazy out of control when powered. I had calculated the CG as a canard, so the CG was off. Recalculated the CG, moved the power pod up to mid-fuselage, added bigger elevons, and it flew...okay-ish.
Mk.I.
More lessons about aerodynamics (lateral dihedral), increased wingspan, bigger motor and threw it up for a maiden today. I didn't even try to video it as the last version crashed repeatedly at first. This one jumped out of my hand and flew nicely on a 2S 900maH battery. The only thing I had to do was give it down elevator which means I'll have to take out the reflex I put on the elevons. Cruising, it ran at about 1/3 to 1/2 throttle.
Four batteries later (two 2S and two 3S 900mah), no crashes, five soft landings, and some flying wing-like acrobatics it came back without a scratch. There may be too much lateral dihedral (angle difference between the front and back wings). The front wing is 3 degrees up and the back wing is maybe 2-3 degrees down. Goofy looking aun to fly!
Wingspan: Front 25 inches, rear 19 inches
Length: 16.5 inches
Motor: 2208 2000Kv
Prop: 6x4x3
ESC: 20a
2 9g Servoes
She needs a cockpit, paint...and maybe French WWII markings.
Mk.III is cut out and ready to put together. It has a longer fuselage. I'll pull the electronics out of Mk.I to put into Mk.III. I still have to figure out a good landing gear arrangement.
I will post plans when I get the rear wing slot the right shape and angled correctly.
You can see the hole for an aileron servo that I didn't put in. I may still add that.
Mk.I.
Length: 16.5 inches
Motor: 2208 2000Kv
Prop: 6x4x3
ESC: 20a
2 9g Servoes
