leaded50
I always liked the designlines of the Diamond twinmotor airplanes . At moment im stuck awaiting for some parts in need to get ready with the Galaxy VSS Unity spacetravel plane, so "needed something to do" while waiting .
Gonna be build at approx. 1000mm wingspan, and goes for two 2208 motors. setup with differential thrust. Since got acess to a 3D printer, use it for some components as the motor nacelles, by combining/adjust some free available parts, that can fit.
Main horizontal internal and the hatch/canopy made of the pvc foam boards i got, and a carbon fiber tube for rear strength.
The plane have a T-tail, and uses a dual layer for the vertical tailfin, to get space inside for elevator actuating, by pushrods through at connector at rear of fuselage... and stiffness of fin for good base for the horizontal stabilizer. To get the space for this.. its a minor adjusting of fuselage diameter fully at the rear though.
the two pictures on top , is the DA - 42.... and the lower one, the DA- 62.
Im not a fan of canopy design of that. ... but i dont like as much the nacelles on the DA - 42 either.... well, i suppose im gonna use some creativity and make what i want on it
