@leaded50 - You my friend are a building Monster! (in a good way) I really like seeing your methods. I always look at the beginning and think there's no way he's gonna... (sees next post) ...Wow, Nice!" You do good work from turning rough models to smooth beauties.
Your production of planes is amazing. My question to you (for which I need help myself) is; Where do you store these?
Do you crash and burn? or is there a secret pile of past planes? or do you confirm flight, then pass them to someone or the trash (after removing electronics.?
All that said - This model is looking great! I have a Girlfriend that might go Flying if I show up with one of these.
- my methods are coming from experience and creativity. I have time to try out
(and enough planes to fly, anyway
Its about "seeing the shapes" on the plane, and how to "replicate it" in foamboard. If by a 3D view drawing, or photos, just measuring to get the correct sizes. Im just following the way i posted in a post on how. No 3d drawing app/program is used, even if PC is used. Resize the resources to the size wants, and measuring!
By that methode, i can replicate any plane, from a 3d view drawing, or enough photos in (hopefully) the similar angles. And if not get all correct fully 100%, its shown it doesnt matter, as long the main lines are there. Nobody sees the minor errors.
On the DA42 here, the end of fuselage to tailsurfaces are a bit too thick eg. I didnt liked it.. but couldnt do it otherwise, it was needed for space to make the pushrod system for the elevator on the T-tail, or evt. if later wanna have rudder too. Ive made a middle-spar at the front window to keep it "stiff enough to keep shape".. if needed with plastic window inside? I dont know, but at moment its atleast stiff enough...and anyway can be removed with window inside if thats enough.
You need find a middle-way to accomplish a build functional sometimes. AND patience! My builds isnt exactly easy ones mainly, they need a lot of work and individually adjustments to get things correct.
Many "shouts" for plans.... they are troublesome to do, my plans is a 3D view drawing (or photos). As an example, if a connection of skins doesnt fit "perfectly" when gluing, what do you do? I use knife and adjust the connections, angle, or remove , or even put in a extra bit if needed.. how to make that on Plans? Plans can never show this minor adjustments "needed" to get the build get best exterior.
On the DA42 ive also altered using three different materials, the pvc plastic foamboard (hatch/canopy - reinforcing for landinggear) and in skins standard foamboard, pluss "Kappafix" a foamboard type who is more like a foamed "swamp"-style. Its more easy bendable/flexible, can easyer be shaped even both ways a bit, but not as rigid as the standard foamboard. But great for some parts for making difficult parts. As on the rear of fuselage behind the cockpit its shaped not as a straight sided cone, but curbed. exaggerated, you can say its from the cocpit and back a "S-shaped" design lines, that can be done "easy" by the Kappafix, not by normal foamboard. Something i learned when working with tests before building the Moonbat XP-67
When stuck medicined, its more than enough hours who wants the mind think of something ells, call it building planes is my therapy. Its cheap anyway, and if see later when in better shape, just to adjust, or dump it!.
I live as single in a smaller appartment..that would say, its planes all over!
Crash and burn happends on some, some few are also passed to others... and some still awaiting the maiden, when hopefully get better shape, and "dare" to risk the plane
. im not an experienced pilot! My local airfield isnt short enough grass, so some needs launched by hand..... and that coordination dont always go good... (i know i need make a bungee launcher!!)
Thanks for the preciation on the build
@FoamyDM
