Flying weight is 26oz.
I was able to throttle back and cruise a bit slower, but I honestly didn't spend much time there
Most of the flights were spent at full throttle just boring holes in the sky and making low fast passes
Landings were easy, throttle-off, so I think that says something good about its glide slope.
I did not consider mixing the elevators in for roll, although I knew you did that. Looking at the control surfaces I was confident that it would have enough authority, and it definitely did. I'm sure there's a way to use a V-bent rod to actuate both elevators from one servo, similar to what I did on the Baby Bugatti; might just have to put the elevator servo in front of the vertical stab.
I DID take the paper of the inside of the spine, and that made rolling the top over not hard at all. Well, the rolling was easy, but holding it in place while I glued the nose and tail areas was a bit of a challenge. What WAS hard was sorting out the nose and the tail closures. I think there needs to be a couple more "darts" in the folding areas.
Also, I think you can make the horizontal one flat piece, and put a recess notch in the fuselage for it to sit flush on.
As for a dogfight; I'm IN! ... although, I'll probably have to build another when I get there. It's a BIT too big to carry on a plane and not worry about crunching it.
