I am so tired of the FatShark pan/tilt camera mount for the 600tvl CMOS camera. It is fantastic in every way EXCEPT that it uses oddball servos with non-standard tooth pitch on the output spline. As a result, when you break the servo--and you WILL break the servo--you cannot replace it with a cheap three-dollar throwaway, nor can you replace it with a decent metal-gear that will be less likely to break. You can't even replace that one gear that always breaks with one from a three-dollar servo, because the drive gears also have a different pitch.
So when a servo breaks, you basically have no choice but to pay $10 to buy the exact replacement servo. It's really frustrating that a high-stress usage like a pan/tilt mount would come with flimsy nylon-gear servos, but if that's going to be the case, the LEAST they could do is let me swap them with three-dollar cheap replacements every time they break.
I cannot recommend this mount to anybody who is considering getting it. Buy one that uses standard nine gram servos, and you can have your pick of expensive digital metal-gear ones or cheap analog nylon ones. I hate, hate, hate expensive proprietary equipment that locks you into a single vendor's ecosystem.
EDIT: Incidentally, the pan/tilt/roll (three-axis) mount may be better, as it seems that the pan servo at least is metal-gear.
EDIT 2: It seems like that servo may have the same non-standard tooth pitch that fits the pan/tilt mount's base, so maybe that would be a good solution to getting at least one metal-gear servo into the pan/tilt mount.
