I bought a used Stone BLue Spectre 2 and it had been pretty messed up around one of the tail boom wing joins. I cleaned up the hole and filled it with expanding polyurethane. I cut new channels and in the in tact EPS and moved the booms slightly inward after cutting channels with a soldering iron.
My question is, I heard that you can use some sort of lightweight spackle for a filling material in the urethane. I have reather large holes in it from where I carved and shaped it to conform to the original airfoil and I want to fill these and smooth the surface out. Anyone have any ideas of a product that can do this?
If not then I am down to Lowes to try and find something.
OOn a full scale composite airplane i would probably use a microballoon slurry. On this that seems like overkill.
Thanks!
Thanks!
