Howdy Folks, Craig A back with plans as promised.
OK, so I'm not always fast. They are large sheets, you'll need to tile to print. You'll also have to fasten 2 sheets of foam board together for the first two plan sheets to fit the long parts. The first plan sheet shows the two sheets of foam board connected in a "T" shape in order to get the main wing to fit. Plan sheet 2 shows the foam board sheets connected long side to long side. Here's a couple of pics with a finished (mostly) model. The black stripes on the Nacelles are a 3M double sided velcro strap that is thin like ribbon. They are just holding the nacelles on until I'm finished the model. The front cones are for display and show up decent in the side view. They will look better once painted black. They are friction fit so they can be removed during flight.
As shown, with the EDF unit installed, it weighs in at 539g.
There are some things I'm still messing with but they are minor things, like servo placement, etc. If I hung onto this until I thought it was 100% I'd never post it. If anyone has any questions please let me know and I'll explain what I'm thinking/doing. I'm also open to suggestion for modifications. I am working on a build guide with pictures and instructions and it should be along shortly. This will be a fun build if you like working with the Foam Board!
