I've constructed a 4-motor FT-cruizer. Only thing I did was to lengthed each wing as long as the foam is long (30"), and space apart the pods so both will fit.
Using 250w 1200kv motors with 8x6 props - 2 being counter-rotating.
I tried flying it with the CG forward of the recommendation - for safety. Well, it shot directly up in the air and was extremely difficult to control. Took everything I had to land it without much damage. It was very tail heavy.
My question is would the addition of the extra thrust cause the plane to behave this way? Or, is the recommended CG way off even with the stock plans??
Have people found the motors need spacers to change the thrust angle??
thanks
thanks
