DDSFlyer
Whew! What a maiden...talk about hair raising! First off I thought CG was on but it was WAY tail heavy and what a handful! Barely got it back on the ground safely...
First issue I need to resolve are the wheels, I'm probably going to heat shrink them on there since the hot glue didn't stick but was able to maiden with some gorilla glue wrapped around the ends.
Second, I turned down the throws to 75% (eventually going to 80-85% after she trimmed out) and 30-40% expo. That made her flyable. I definitely have some tracking issues due to the right aileron trim is needed to get her to fly straight but that's no big deal.
Third the props are so much POWER! I think I'm gonna go with the 8x4.5 slow fly props I got instead of the master airscrews because my motors were getting a little warm and it just climbed with power but dropped down fast without it. Plus it's sucking the juice pretty good out of the 2200mAh and 2650's that I put in.
Fourth, and the biggest, is I've gotta find some better CG fix. It is tail heavy, so I put a AA battery in the bottom of the nose all the way forward just to help her out. I don't like making the plane any heavier but I don't see much of an option yet. I may see if I can push the ESCs farther forward in the pods, but I to get some lead weights to add forward to get this thing to center better.
As far as it being my first scratch build I'm super happy with it coming home in one piece. Two really scary flights and what some would call landings and 3 more trimming flights with actual landings later and I'm home trying to let off the "shakes" of excitement of maiden flight!
