Twin Viggen
I figured this was going to be a boring winter with few opportunities to fly so I bought 2 FT Viggen kits to make a twin Viggen, something like the twin P-51 Mustang. I've got it almost finished now, with only painting left and then to install all the control horns and Rx. I've built it as a twin, counter-rotating 70mm EDF, 3000KV motors, 6-blade fans, running on 4S twin 2200mah batteries, twin 50A ESCs. Don't know if it'll fly. Will find out when spring comes.
It's double re-enforced with one carbon spar for each each plane plus a square carbon rob that overlaps the 2 to prevent the wings from folding. The central rear control surface is mixed for elevator function only. The inner canards are glued together where they meet and this makes the front of the structure quite stiff. Additionally, I've installed a 5mm round CF rod that spans the 2 top ridges for more stiffening and for a hand hold when launching. It also happens to be exactly where the CG is. It balances with the batteries just sticking into the pointy beak. I could go with 3300 mah, 4s bats that would live entirely in the battery bay and give longer flight time, but that would be an added expense since I have lots of 2200's around. As is, this is likely the cheapest twin EDF plane I've had. It's a bargain if it flies.
I had a single Viggen with a similar drivetrain but augered it into the dirt when I lost it in the sun. I've always wanted another one since. David did a terrific job of designing this plane and his build video has been a tremendous help. Too bad they exported him back to his home country. I hope he's doing well.
