Micro FT Flyer, and thank you first!
Did you use flat wing or use dihededral and how much?
Works great too! A really small FT Flyer that flys great - very nimble! The only thing I need to figure out is how to get the prop saver to actually save my props on this one. I've broken a prop on landing almost every single flight. I added a "landing wire" that will hopefully protect the front end a little bit more, and I'm going to try opening up the prop shafts a little more too so they are a little looser on the prop saver.
you should do a mini Bronco
I have thought about doing a twin. A bronco would be cool, so would my PBY shrunk way down. With micro motors I could probably get the wingspan down to 30 inches.
Micro PBY? I'd be super interested in that!
I love mini and micro planes, give me more room to build more planes while saving on cost of building.
If you need plans of Drawings I have lots of them for Bronco. I am working on flying Pancake now, use my Duet motors View attachment 68714
what is a PBY ???
@LocalFiend,
Do you have a Thingiverse account? I'm LitterBug over there too. Not much posted up yet on my channel.
Cheers!
I built a micro flyer and it Flys great .It even huals a 600 mah 2s around without difficulty .
LF,
Are the plans available for your 100" Giant PBY? I'd like to try building that one.
Thanks,
I will look. I think I cleaned them up a bit for someone else in the past. Keep in mind that there were some errors, and I had to cut some parts by hand at FF when I did this. Been too long for me to remember what the exact issues were, but they were small enough to be fixed in the build tent by hand fitting.
Under Construction:
Micro Sopwith Camel
Micro Spitfire
Hughes P21-J MkIII Devastator Swappable
Micro Russian Thunder
39" Messerschmitt Bf 109
42" Gloster Gladiator
Mighty Mini Bf 109
Hughes P21-J Mk III Devastator
Swappable Floats and Skis
Finished Builds:
Mighty Mini A6M Zero Swappable
Build Thread
Mighty Mini A6M Zero v1.1 Full
Mighty Mini A6M Zero 1.1 Tiled
AUW - TBD
25" Wingspan
Designed around Power Pack F
Motor: 2204 2300kv
ESC: 12 Amp
Prop: 5030-6045
Servos: 4 - 5 gram
Battery: 800mah 3s-4s
42" Mitsubishi A6M Zero Swappable
Build Thread
42" Mitsubishi A6M Zero Swappable Beta Plans v.2 - Full
42" Mitsubishi A6M Zero Swappable Beta Plans v.2 - Tiled
Scale DTF Floats for 42" Zero - Tiled
AUW - TBD
42" Wingspan
Designed around Power Pack C
Motor: 2215 1180kv
ESC: 30 Amp
Prop: 10x4.7 SF
Servos: 4 - 9 gram
Battery: 2200mah 3s
Micro FT Flyer
Tiled Plans
All Up Weight 70 grams
16" Wingspan
6.4g HD1610 3400kv Motor
5030 Gemfan Prop
6AMP Plush ESC
3g Servo x2
Full Size Receiver (Cover Removed)
Gift Card Firewall and Servo Horns
180-260mah 2s (Actually, the plane has a ton of power, it'l haul a 500mah 2s just fine and fly for a long time)
10 Minute Flight times with 260mah 2s
Micro F22
Tiled 8.5x11 Plans
Full Plans
Decal Plans Full
Decal Plans 18x24
Decal Plans 8.5x11 Tiled
Jumbled up Build Thread:
http://forum.flitetest.com/showthread.php?21299-Micro-Indoor-Flyers-Re-Purposed-Designs
13" Wingspan
5030 Gemfan Prop - 5" Maximum Prop Size
6AMP Plush ESC
1.7g Servo x2 - Dual Elevon Setup
Micro Receiver
180-260mah 2s
6 Minute Flight Times with 260mah 2s
