Micro Indoor Flyers - Re-Purposed & Profile
Thought I would make a thread separate from Nerdnic's Manic Micros. One of his criteria is clean lines and no exposed electronics, and I don't want to muck up his thread with some of the micro stuff I've been messing with that doesn't fit there.
Lot's of people wanted something smaller than the current Mighty Mini Series for flying indoors and in tiny lawns. Rather than re-invent the wheel and create completely new designs (though I am doing that as well), I thought some of the current flight test offerings could be scaled down with minimal effort. I wanted to keep the FT strength and build speed, as well as use a full size receiver. Makes the build that much cheaper.
Here's my first offering:
The Micro FT Flyer: (and after some searching, I'm not the first one, this has been done several times)
All Up Weight 70 grams
~16" Wingspan
10 Minute Flight times with 260mah 2s
6.4g HD1610 3400kv Motor
6AMP Plush ESC
3g Servo x2
Full Size Receiver (Cover Removed)
Gift Card Firewall and Servo Horns
180-260mah 2s (Actually, the plane has a ton of power, it'l haul a 500mah 2s just fine and fly for a long time)
Plans: http://www.lfarmory.com/webapps/RC/Plans/MicroFTFlyer/Micro_FT_Flyer_Plans_v.1.pdf
Once the Manic Micro Power Pod size is decided on, I will make this swappable with those.
Carbon Fiber Rod to steel z bends. Just use a bit of heat shrink and some CA. This is really light, and also allows you to get your control rods the proper length almost as easily as mechanical linkage stoppers.
I removed all the paper from one side on every part in this build. I wanted to keep some for the strength (removing both sides without adding something like tape makes for really weak wings), and to test if it would fly like this. I really wanted to keep the speed aspect of the build intact. Removing the paper from the wing bottoms also gives a cool birdlike bend to them.
Here's the guts. I actually fitted the receiver a little deeper in than shown to make more room for the wing when it gets glued in place.
Weight:
~16" Wingspan
6AMP Plush ESC
3g Servo x2
Weight:
