Mounting servos ... I really like using a ball and link style chain to fish servo wires through - so much easier than trying to push a wire in
Mixing up a small batch of epoxy to glue in the hinges with my favorite tool - a broken prop! Make sure to add a drop of oil to the hinge pin before starting, put epoxy in the slot on the surface, and then insert the hinge. And only do one side of the hinge at a time.
Fast forward to after dinner, and putting the other side of the hinges into the wing.
And a little more epoxy to mount the tail. Even without the magnetic building board, the right angle supports are useful to keep things aligned here.
When I woke up this morning, I realized that I probably need to add a piece of triangle stock for support on either side of this joint. I'll try shaping and covering it first, and then peeling up a little more covering from the tail and gluing it in place. Not worried about in flight performance here, but I do want to make it a little more resistant to hangar rash.
