The Zohd Kopilot hasn't arrived in the post yet. It was originally intended for an A-10 I'm working on. The A-10 is setup perfect for maiden flight at the minute. I was just looking for it as an aid for the auto launch and RTH. I wonder if there is a way to do it without throttle and rudder function? Just have it stabilize pitch and roll.
Think I might just have a plump up for an Aura 5 in the future. Though that can wait for next build.
Ok cool upcoming project got it, so here is what I have done regarding mixes so far testing...after the zohd was setup and tested to be working correct, I decided to test a mix >>>BUT this after the zohd was all setup and calibrated with control board, adjusted and saved
I tried a fairly harmless mix of inducing 15% up elevator at the flip of a toggle switch, ....baby steps baby steps, then I added elevon differential again there are no ill affects, Im going to test more mixes soon as weather permits, its been raining for weeks, but I think all will be OK since the zohd setting were saved and the mixes are programed afterwards
so I would try setup using a standard T tail, setup ONE motor connected and get the zohd setup and responding proper on the bench, then program in your differential throttle and test again on the bench to see if you can it looking like its responding to make you feel comfortable testing it .I really dont know what to expect, none of the disscusion boards I visit regarding the zohd have posed the question
if you try to get the zohd working with diff thrust please post what you find, Im interested for future projects as well
