The charging process isn't the only thing that can puff a lipo. Discharging it too fast, storing it for long periods of time fully charged or discharged, and discharging it too much are some other examples of how you can puff them.
When you say that "the highest is 2.2" what do you mean by that? Is this a 2200 pack where 2.2 amps is 1C, or is the capacity different?
I really doubt your problem is caused by charging too fast either way, so you should check for some other things:
Do you storage charge the batteries before storing them?
Have you made sure that your charger is charging to 4.2 volts per cell and not any higher?
How much do you discharge them? 3.0 volts is the absolute minimum for a lipo, but I typically don't even let mine get below 3.7.
What is the capacity and C rating and how many amps are you trying to pull from it?
