Having some of you are following me both on this project and the FTFC22 Build Raury Challenge then it's best I post an update about this project before going on to the FTFC22 challenge.
Here are all the last steps of what I have done until now.
1) I have the wing supporters that help the wing stay straight every you put them on.
2) I have added foamboard doublers to the inside of the wooden support piece that I have create at my friend's place and then later mounted at home.
3) Next up was adding the BBQ skewers for the rubber bands to mount onto. I installed the thickest BBQ skewers that I could find. I was actually kinda debating what to do here between have some sort of screw mechanism like you see on balsa models or using plain old simple rubber bands. As you see I ended going with the cheap, plain and simple
. Getting the BBQ skewers through was a little bit of a pain in the butt and I had to use a drilling tool to make the initial hole through the wooden piece.
Quick glance of it set up again and compared to it's brother the 238% scale of the Mighty Mini Tiny Trainer.
4) Because of it's size and the fact that the wings are on the bottom this plane would be hard to hand launch let alone by myself so I have decided that it need a set of wheels, and not just front wheels and a tail dragger as I would normally do. Searching the forum and FliteTest website and came across this which I liked:
. Scaled it up and started working, sorry I didn't really document that part of the build but I really just copied the video and it went together quite well even when scaled up.
5) I had to connect the control surfaces to the 9g servos that I have mounted on the tail and wings. Starting with the elevator and rudder I have faced deflection issues where the control surface wasn't moving in one direction. At first I thought it's related to the servos that I am using which couldn't move such big control surface especially since the fuselage is built out of 10mm FB. So I went out hunting for bigger and stronger servos, which by chance a friend and college from work had at home so with out further ado I made sure to get them. After playing around with them hand held I have realized that the servos might also be a problem but my main problem is actually the pushrods that I was using they were bending when the servo arm was going in one direction the same direction in which the control surface had zero deflection. Not having thicker pushrods that can fit in my 9g servo control arms that were still installed in the plane. To solve my issue I have come up with a different solution! I used some ~2.5mm carbon fiber rod that I had laying around and connected to either side of it the thin pushrods that I had using some CA and hot shrinks to get this. Testing it with the installed 9g servos proved that the wire was the main issue so to save weight I have decided not to swap out the servo as well and stick to what was installed. I also used bigger control horns obviously scaled according to the rest of the plane. On the wings I didn't seem to have this issues because the pushrods there were shorter as I mounted the servos differently that on the original model and they ended being closer to the control surface itself.
6) Last thing I did on the model and this is also where I am stuck or on hold call whatever you like it the installation of the front wheel set. First thing to mention about this is that I originally planned to install the front wheel support before folding up the wing which should have possibly given it more strength but I forgot to do it, so I ended up doing it exactly as shown in the video. The first thing that I did was cut slots down in the wings and built the supporters exactly as in the video measuring things to my scale. The only difference was that I only cut out supporting pieces to sit on top of main plate rather than cutting a full sized piece with a groove on it for the wheel mount to go into. The hardest part in this was cutting and bending my 4mm steel wire to the size and shape that I wanted. I ended up having to heat on the stove to get it to a point where I can bend it with my pliers. Luckily I was also clever enough to use a BBQ glove which actually saved my hand cause the wire was super hot to a point that even under running water it still took it a while to cool down. It all still needs to be glued to place but this is how it should look. Cause it was so hard to cut the wire I went out to get a saw for it to make it easier to cut.
Is it too high? Cause it feels a bit unstable wiggling it from side to side.
To sum up this post this is what I still have to do.
1) decide if I want to make the front wheels holders shorter or not. Think I’ll measure it out according to the proper that I want to use. Also need to get gorilla glue for this.
2) to decide if I want to use the motor that I have installed that can pull 2.1kg or get a new one that can pull 5kg. This will obviously mean that I need a stronger esc and bigger prop. I am leaning towards getting a different motor cause I don’t only want to get airborne I want speed as well.
3) paint this beast, and I haven’t decided how just yet.
What’s your thoughts about the height of the front wheels? The motor issue? The paint scheme?
Let me know…
