With cooler weather in our future, I'm getting the indoor flyer bug again and dug this little beauty out of the future project pile. The microMAX 103 is a semi-scale indoor model of the Team Mini Max home built kit plane.
The balsa kit is of exceptional quality with smart design choices and perfect laser cutting as one expects from Steven's Aeromodel. https://www.stevensaero.com/StevensAero-microMAX-103-Laser-Cut-Micro-RC-Kit.html
The basic fuse went together quickly without need for pinning or clamping and is just waiting on arrival of the right motor and gear box (the one I had on had uses a stick mount instead of the pillow block style).
I have always built with pins on foam board before, but all this talk of magnetic work surfaces on the forums lately has me trying new things (it's all your fault Joker )
Being a cheap old coot, my first metal building surface is a flat cookie sheet that's been exiled to the shop, and a handful of magnets I had on hand. I really like how simple it is to get good clamping pressure, and to make adjustments as I'm gluing up or adding parts.
This obviously isn't going to be big enough for anything other than indoor flyers, but it's been a good place to start tonight. I'll be picking up a larger piece of sheet metal, ordering a set of 90 degree sandwich magnets, and maybe getting a set of jigs from Laine's Planes too.
My goal is to have this plane finished in time for a local indoor fly-in in two weeks, so expect rapid updates on this thread
