OK!!!! Try this out. It should work...
#include <OneWire.h>
#include <DallasTemperature.h>
#include <DHT.h>
#include <LiquidCrystal_I2C.h>
#include <Servo.h>
#include <MyDelay.h>
#define heat 4
#define leftsw 5
#define rightsw 6
#define alarm 7
#define humid 8
#define ONE_WIRE_BUS 3
#define DHTPIN 2 // Digital pin connected to the DHT sensor
#define DHTTYPE DHT11 // DHT 11
MyDelay TurnDelay (5000);
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
LiquidCrystal_I2C lcd(0x27, 16, 2);
Servo myservo;
DHT dht(DHTPIN, DHTTYPE);
//declare global variables
float dt, counter;
unsigned long current_time, prev_time;
bool toggle = false;
bool busy = false;
float Temp;
float Humidity;
bool delaystarted = false;
void humidity()
if (dht.readHumidity() < 65)
digitalWrite(humid, LOW);
if (dht.readHumidity() >= 70)
digitalWrite(humid, HIGH);
void temp()
if (sensors.getTempCByIndex(0) < 30)
digitalWrite (heat, LOW);
else if (sensors.getTempCByIndex(0) >= 30)
digitalWrite (heat, HIGH);
void checktemp()
lcd.setCursor(0, 1);
sensors.requestTemperatures(); // Send the command to get temperature readings
Temp = sensors.getTempCByIndex(0);
lcd.print(Temp);
lcd.print("* ");
if (Temp >= 20 && Temp <= 30)
digitalWrite(alarm, LOW);
lcd.setCursor(0, 0);
lcd.print("ALERT TEMP! ");
void checkhumidity()
Humidity = dht.readHumidity();
lcd.print(Humidity);
lcd.print("% ");
if (Humidity >= 20 && Humidity <= 30)
lcd.print("ALERT HUMIDITY ");
void rotate()
if (toggle == false)
if (digitalRead(rightsw) == LOW)
myservo.write(180);
busy = true;
else if (digitalRead(rightsw) == HIGH)
toggle = true;
myservo.write(90);
busy = false;
else if (toggle == true)
if (digitalRead(leftsw) == LOW)
myservo.write(0);
busy = true;
else if (digitalRead(leftsw) == HIGH)
toggle = false;
myservo.write(90);
busy = false;
void setup() {
Serial.begin(9600);
sensors.begin();
lcd.init();
lcd.backlight();
myservo.attach(9);
myservo.write(90);
pinMode(2, INPUT);
pinMode(3, INPUT);
pinMode(4, OUTPUT);
pinMode(5, INPUT);
pinMode(6, INPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
lcd.clear();
checktemp();
toggle = false;
void loop() {
// put your main code here, to run repeatedly:
checktemp();
temp();
humidity();
checkhumidity();
Serial.println(digitalRead(leftsw));
if (delaystarted == false && busy == false)
TurnDelay.start();
delaystarted = true;
if (TurnDelay.update())
rotate();
TurnDelay.stop();
if (busy == true)
rotate();
