CheapSunglasses
I examined the horizontal stabilizer and the damage is worse than I thought. I discovered that the elevator is cracked in half. I was hoping that I could leave the horizontal stab trailing edge, elevator and hinges intact but it looks like I’ll be replacing them. The existing control surfaces appear to have small pin type hinges. I was thinking about using Dubro nylon hinges in the new elevator…if so, should I use the small or standard size?...or should I just go with CA hinges in the new elevator?
Remnants of horizontal stabilizer showing existing pin hinge.
