Hello!
I'm a completely novice/whatever... in the rc aircraft world and i've got an objective for christmas. BUILD MY FIRST TRICOPTER!
I love building, whatever it is, and i want to feel the experience of building and using one of these, as I've seen they're totally awesome.
I have watched almost every video of flite test and david windestal which talk about tricopters and i have come up with a configuration that i think it will work.
But as i'm not experienced with electonic terms and physics and that kind of stuff, i need some help.
Could you please tell me if these parts would work good together or if there would be any problem?
I was very doutful with the props, motor, esc and battery compatibility but i'm not sure.
NTM Prop Drive 28-36 1400KV / 560W:http://www.hobbyking.com/hobbyking/store/__25078__NTM_Prop_Drive_28_36_1400KV_560W.html
Afro ESC 30Amp Multi-rotor Motor Speed Controller (SimonK Firmware): http://www.hobbyking.com/hobbyking/store/__39708__Afro_ESC_30Amp_Multi_rotor_Motor_Speed_Controller_SimonK_Firmware_.html
TGS Sport 8x4E Precision propeller: http://www.hobbyking.com/hobbyking/store/__7944___TGS_Sport_8x4E_Precision_propeller.html
Hobbyking KK2.1.5 Multi-rotor LCD Flight Control Board With 6050MPU And Atmel 644PA: http://www.hobbyking.com/hobbyking/store/__54299__Hobbyking_KK2_1_5_Multi_rotor_LCD_Flight_Control_Board_With_6050MPU_And_Atmel_644PA.html
Turnigy 3000mAh 4S 20C Lipo Pack: http://www.hobbyking.com/hobbyking/store/__9264__Turnigy_3000mAh_4S_20C_Lipo_Pack.html
Turnigy 9X 9Ch Transmitter w/ Module & 8ch Receiver (Mode 2) (v2 Firmware): http://www.hobbyking.com/hobbyking/store/__8992__Turnigy_9X_9Ch_Transmitter_w_Module_8ch_Receiver_Mode_2_v2_Firmware_.html
TGY-210DMH Metal gear Coreless Digital Servo w/ Heat Sink 3.9kg / .13sec / 16g: http://www.hobbyking.com/hobbyking/store/__23459__TGY_210DMH_Metal_gear_Coreless_Digital_Servo_w_Heat_Sink_3_9kg_13sec_16g.html
Aditional info: I've based in recommendations and basic knowledge to choose these components. The motor i chose is because when i adquire some expertise, i'd like doing aerobatics, and i saw a video in youtube that a good kv for aerobatics is 1400.
Thanks!
Thanks!
