Quick and clean Aaron! Do you like the Scout better than the Cub? We may end up building one of the two for the UND R/C club and I want to get a community census for which is preferred.
Well done, I think I passed you when you were going out for your maiden, I should have stayed. You had a heck of a wind to contend with. Can you tell me what motor and prop you are using?
I'm just starting my build with a "B" mt2213/935kv. But I am finding the video mentions A or B and web site suggest conflicting B or C power options. I'd like to make sure the mt2213 will do the job. Thanks
Does anyone have a link to printable stencils for the red baron paint scheme?
I am considering building one of these using the free plans. This would be my first build so tell me how the free plans work. Do I just print them all out on 8.5x11 pieces of paper then tape them all together. Once I do have them printed out, should I stencil the plans onto the foam board or cut through the paper and the foam board? If I do print them out in the wrong size, can the plans be scaled up or down as long as the whole thing is the same size? Sorry for all the noob questions, Thanks for the help!
Here is my setup:
Bought the kit at FFS store tent. Everything else was from my stash.
Emax servos left over from FT powerpacks
NTM 2826 1200kV that was $5 at HK (it is a bit bigger than a B motor but not quite C)
Turnigy 30a plush
China hobby 1000mah 3s
Orange DSM2 6ch rx - worked ok as not a lot of flyers in the air
8x4.5 - could easily use 9x6
I would think your mt22123 should work fine, use a 10x4.5 on 3s. I believe many motors will work as long as you size the battery accordingly, smaller motor (A to B size) = smaller battery(800-1300mah) and larger motor(B-C size) = large battery (2200mah+).
