Release Date: September 18, 2017
Description:
The X-29 was developed by Grumman in the 1980s as an experimental aircraft to test new design technologies such as using forward-swept wings, full-flying canards and carbon fiber composite materials.
We have simplified some aspects of the plane to allow it to be constructed out of foam board and common materials while still retaining the sharp looks of the design. The aircraft’s unique flying characteristics such as its gentle stall have also been retained, but the inherent instability of the full-scale aircraft has been improved in our foam version.
Its relatively short, air foiled wing and long fuselage keeps the plane tracking straight in fast passes and allows it to slide into sharp turns while still having the locked-in feel. The speed and agility as well as its slightly more complex build means that it is a good fit for intermediate pilots and builders.
The FT X-29 can be flown with the Power Pack C motor in a pusher configuration, or it can be powered by a 64-70mm EDF, expanding the jet portion of the Flite Test speed build kit fleet.
- Andres Lu
- Andres Lu
Specifications:
- WEIGHT WITHOUT BATTERY: 1.65 lb (.75 kg)
- CENTER OF GRAVITY: 22.75 in (577.85 mm) from the nose
- CONTROL SURFACE THROWS: 30 ̊ deflection - Expo 30%
- LENGTH: 45.5 in (1155.7 mm)
- WINGSPAN: 27.5 in (698.5 mm)
- RECOMMENDED MOTOR: Park 400, 1100 kv minimum or 64-70 mm EDF w/appropriate ESC
- RECOMMENDED PROP: 9 x 4.5 CW on 4s
- RECOMMENDED ESC: 30 amp minimum
- RECOMMENDED BATTERY: 2200 mAh 4s - 4200 mAh 4s
- RECOMMENDED SERVOS: (2) 9 g servos
Store Links:
Speed Build Kit
Power Pack C
Article: FT X-29
Videos:
Preview Video: $30 DIY JET | VLOG0087
Release Video: DIY NASA Jet | FT X-29
Build Video: DIY Jet | FT X-29 BUILD
Build Article:
Plans: All-In-One | Full-Size | Tiled A-Size | Tiled B-Size
Simulator Files:
