I will once I get this prototype working (or crashed) and make some final adjustments to them. The nose section that hooks into the fuse is a bit tall and I think that's due to a problem with the plans printing/tiling. So I want to get those types of things ironed out.
Got the power pod, servos, rods, and control horns all installed and everything wired up and tested with the RX. Just had to reverse the ailerons in the TX. Now if I can just get some good weather I can go and fly or crash this thing the way it deserves to be.
I'd send you my calm winds 80 degree southern california weather to you if i could, but I can't, so just send the plane to me for testing . I'm looking forward to the test and plans
Thank you Jason for doing this build! I was hoping to download the tiled prototype plans but unfortunately the link does not appear to work. Do you have another location where the prototype plans can be downloaded? Thanks again
I second those links. I've given up on a true swappable format. I'm going to tinker with it and see if I can make a slightly smaller version that is a dedicated pusher.
