ironkane
Please call me IK or Steve. IronKane is great for gaming, not so much in a CNC forum thread
I printed out a new cutter mount and fired it up. Sounds rough on the low end, but the sweet spot is somewhere around 3/4 throttle. I thought about what Jason was saying about the deflection to the right. It's actually the way it should look. When at 12:00, the needle is around 5 mm right of center. As it rotates CCW (tightening it's grip on the bearing) the needle moves towards center so you get that one sided deflection.
I threw my old paperless DTFB waste board underneath and ran the cutter like a scroll saw and the the results were excellent.
I picked up some M3 set screws to Locktite into the opposing motor mount holes. My plan is to start with the one 180 from the needle and spin it up and then try the other two holes as well. My hunch is 3 will be better than 1. Hopefully this will be all that I need to balance it.
Taking Wednesday off to work on the vacuum table and a laundry list of other details. If all goes well, maybe I'll even run some gcode. That is if I can figure out what's with my Estlcam. Documentation says it's not only compatible with xPro CNC controller, but it was on the list of new features for the latest version. But when I try to program the Estlcam CNC control, it crashes Estlcam. Maybe I need to use the 32 bit version?
Then it's on to designing/printing a mount for my 3.8W laser. And address the unique wiring issue that the laser driver presents.
The plotter pen mount should be simple after that.
