nhk750
Aviation Enthusiast
I use dielectric gel at work to seal connections on forklifts and also to protect exposed electrical terminals in high exposure applications. I need to install some servo extensions in my Tcraft wing and I was thinking about using some dielectric gel in the connections and then heat shrinking the connection as it will be permanently in the wing to prevent any corrosion. I know the best way would be to cut out the connection, then solder the wires together, but this would be a lot easier. Has anyone tried dielectric gel for this? This is what I use at work. https://www.amazon.com/Super-Lube-21030-Synthetic-Grease/dp/B000XBH9HI/ref=pd_sbs_328_4?_encoding=UTF8&pd_rd_i=B000XBH9HI&pd_rd_r=596JG6S7CP2K4AFM60VH&pd_rd_w=yubal&pd_rd_wg=KgRyR&psc=1&refRID=596JG6S7CP2K4AFM60VH&dpID=31-xhQ8JfAL&preST=_SY445_QL70_&dpSrc=detail
