Hi all,
I got an ft versa for Christmas, and only recently got around to starting building it. I hooked up the electronics a while ago, though, at like the end of December. I sottered the connectors (ec3) to the esc, then plugged in the receiver and motor, and powered it up. It worked fine, the motor spooled fine and and the connection was strong to the transmitter (range checked it). School work and ground school called though, and I stuck the electronics back in the box and put it away for a few months. Fast forward to a few days ago when I started assembling my versa. I got out the electronics to test the servos. When I plugged in the battery, though, something crackled as I pluged it in, then nothing. Thinking it was a shotty sotter joint, I took the esc to school with me and re-sottered it. I just got home and pluged it in, and it does the same thing, just a crackle and the light on the receiver glows faintly for a fraction of a second, before the plug is fully connected. I think it may be that the connectors are not making contact, but I don't know. The esc has ABSOLUTELY no reason to be shot. It's a 30a with a 1300 3s, so that should be good. Also, there has been no smoke, which is what I hear happens when you cook an esc. Any advice/ diagnosis? Thanks!
