Woo Hoo! Lets break some records...who's supplying the records?
A suggestion would be to launch in order of altitude and flight duration capabilities -- say, High/mid/low... and then orbit the field in the same direction to avoid collisions. Launch and set up the high-altitude long-duration aircraft first, and get them orbiting in a "stable" pattern. Then repeat for the mid-level planes, then the low.
I'd kick in an extra $7 to be part of this!
Flite Test is in! Austin definitely wants to participate in the attempt and said the other guys would love to as well if they are available. Austin is going to include information about it in the next email update for registered pilots. That should give us a huge boost in getting the numbers that we need to pull this off.
I think the next thing we need to do, is decide the date and time that we are going to attempt to beat the record. The sooner we get that nailed down the better.
Something else to consider . . . Signal density.
Spreading the wealth among different protocols won't actually reduce the signal density since they all compete for the same bandwidth (although it gives us a chance to warn someone using a weaker protocol to fly something big and pretty . . . Wilsonman), however spreading pilots along the flight line and keeping the planes closer to the corresponding pilots will reduce the density quite a bit.
We also have to take the neighbors into consideration.
To the east is a populated neighborhood (which is on good terms with the Furey's -- let's strive to keep it that way ) so I'd propose the 4 groups be spread more-or-less along at most 4/5ths the flight line (peanut butter spread or gaggles of pilots? I lean toward gaggles). with the LOWEST altitude CLOSEST to the neighborhood but with at least a 1/5th of the field empty for buffer -- the lower the altitude the less likely a rogue airframe (very likely) will glide into the neighborhood.
Craftydan - duly noted.
Is the infamous pump located east by the neighborhood or opposite it to the west? Will we need to cut off both ends of the field to account for both items?
I think this is a no-brainer.
Saturday, Noon. Should be the peak of the event attendance, so we have the most interested/available pilots and the biggest audience to see it.
Only reason to try it any earlier is to have a chance to reattempt due to weather.
Okay, so sounds like Austin is in agreement with Saturday being the busiest day. We should also have a backup rain date. Maybe Friday?
