In the spirit of plans for an air race theme for FTFF2017 I am pulling the wrap off my intentions for a build. This means that I will not be doing a balsa build this winter but I do feel that this is an equally exciting subject.
Stats:
Scale: 1/6
Span: 54 inches
Power: TBD
Retracts: Yes
Estimated weight: 5 pounds
This will be a COMPLETE scratch build. No previous plans or forms. In my usual true-to-scale fashion I have done some extensive research to find the proper airfoils and I've worked out the math for the design. Wing will consist of NACA 23012 airfoil at the root with NACA 0008 at the tip. No twist in the wing as to overly complicate the stresses from a forward-swept wing. Tail will be the scale NACA 0011 airfoil. These are what is generally approximated by the Bugatti 100P project after taking careful measurements of the original. While not exact, they are proven airfoils.
Dihedral of main wing measured at 7 degrees total and V-tail is at 130 degrees. Main wing incidence at 0 degrees as well as V-tail. I will deviate from true scale and not do split flaps as at this size the numbers tell me that the upper flaps will not do much for me but I will have better stall characteristics with a full flap at lower air speeds. In reality, both flaps (upper and lower) would extend down for landing anyway. The split flap design would add weight I am not willing to take a hit for. Tail planes will be aligned using a Y former made from ply to set angles correctly and better ensure tail incidence. Wing spar will be from ply and pass through the fuselage. Wings will be separate panels that will be affixed into cups carved into the fuselage to ensure proper wing incidence.
Size was chosen because of a lot of convenient sizes. First, the span allows me to make this all one piece but still be a sizable model. Wheels are 3" at scale (good for grass runways) and spinner is at a convenient size as well. The canopy is small enough that I can vacuum form my own. There is also the issue of weight. At this size I can do a quick layer and carve of the fuselage and the wing thickness at the root chord is just under 2" (perfect for my pink foam technique). Everything is just sized to be an easier build.
Power is TBD. I can run a single motor with no issue if size accordingly and I have ample electronics on-hand to do so. HOWEVER, if I can find the right machinist I can get a few custom parts made to include the contra-rotating props on a dual brushless motor configuration. The Himax contra motors are currently the only option at this size and honestly, they do not put out the power that I would want for this model. And they are insanely expensive. If anyone has talent in machining or "knows a guy" please let me know.
Hope to do this one justice as it is a beautiful subject and sure to be quite fast. I'm going off of 3-view drawings from Louis de Monge, the chief engineer. Hope to make him proud as well.
Edit 23SEP2016: Hobby King is the official sponsor of the Bugatti 100p project now.
Stats:
Scale: 1/6
Span: 54 inches
Power: TBD
Retracts: Yes
