Like a few others I see on here, I'm planning to run my 1000mah pack in the Mini Arrow. The stock pod is about 31mm wide. From a brief look through battery sizes online, 1000-1300mah packs usually run about 35mm wide. I used my meager Inkscape skills to redraw the pod and hatch plans to accommodate this.
I'm going to try out my plans this weekend. I'll post them here now in case others are building this weekend and want to try them out, too. Since DTFB is 3/16" thick, I added 3/8" (which is about 1cm) to the total width of the pod.
If you use these plans, keep the following in mind:
1. I haven't tried them yet, so use at your own risk.
2. The stock power pod should still work if you put a piece of foamboard on each side as a spacer.
3. You'll have to change the wings somehow. Either:
- cut more out of the top surface. I think this will cause the leading edge to not meet up with the front corners of the pod.
- use a 3/8" spacer between the wing halves on the bottom. This will increase wingspan and maybe change flight characteristics???
- come up with your own solution
Feel free to use/modify these as you wish. Thanks to Sp0nz for providing the excellent plans for me to hack on.
View attachment FT Mini Arrow Widened Pod v1.0.pdf
