Ready for maiden!
I worked on the details today and its ready for maiden flight. So, this build thread is just about done. I will post a video of the maiden flight when it happens and I also did a time lapse build video of the entire build that will take some time to process.
Two things I left out on the build were, no wing struts as the Great Planes design did not use them as structural parts and they even recommend removing them for high speed flight. I may build some for static display purposes some day. I also did not build the wheel pants as I will be doing grass field operations and I also like the look of open wheel aircraft. Here are my final build specs and everything. I also did a Watt meter test to compare to the Ecalc results and it came out very close. I am heavy at the top end of 4.5 lbs and that is the max for this plane, but I have plenty of power. It will just have a high stall speed...One amazing thing is that my CG came out nearly perfect without having to do any adjustments...got lucky!
Great Planes Taylorcraft 20 build specs
Build time April, 2017 to Sept, 2017 (6 solid months)
AUP with 3,600mAh, 40c, 4s Admiral Battery –
2,050grams, (4.52lbs)Yikes!
HiTec HS-85MG (Metal Gear) servos for ailerons
HiTec HS-225MG (Metal Gear) servos for rudder and elevator
E-flight Power 32 brushless motor
E-flight 60amp ESC
Spektrum AR6600T (6 channel telemetry receiver)
Prop, APC 12x8E
Predicted Ecalc specs:
Wing loading: 20.3 oz/ft (squared)
Est. Stall Speed: 23 mph
Est. top speed: 65 mph
Motor maximums:
Motor electric power: 756 watts
Motor amp draw: 53.87 amps
Static thrust: 3532 grams
Thrust-Weight ratio: 1.77:1
Efficiency optimum: 86.7%
Efficiency max: 81.5%
Measured Motor specs with watt/amp meter full throttle:
Motor electric power: 729 watts
Motor amp draw: 48.3 amps
Battery volts: 15.09 volts
Measured Motor specs with watt/amp meter, 50% throttle:
Motor electric power: 148 watts
Motor amp draw: 8.9 amps
Battery volts: 16.44 voltS
Here is a video of my Watt meter in action.
Here are some final pics.
Here is a comparison shot for the aircraft paint scheme I modeled this after.
