Help! Millennium flerken power pack for mighty minis?
Ligbaer
50 Percenter
The milliniuem falcon power pack is a power pack f se So it should just be a hand in hand replacement for power pack F. I havent bought the power pack in a long while (as i find it cheaper to part out the power systems) but i have used the ft2207’s and I can personally say that they are very nice
luvmy40
IDK if the FT Millennium Flerken add on has reverse threads on the prop shaft. I just know that they do exist in the wild, specifically for twins. I would assume a pusher would maybe have the same reverse threaded shaft.
RossFPV
Where do you buy your electronics?
ShadowUAV
Wouldn't the Flerken power pack have CW motor(Shaft threads CCW)?
No the motor spins ccw as it should as viewed from the tail and has a pusher prop designed to spin cw as viewed from the nose. This prevents the nut from spinning off
