The milliniuem falcon power pack is a power pack f se So it should just be a hand in hand replacement for power pack F. I havent bought the power pack in a long while (as i find it cheaper to part out the power systems) but i have used the ft2207’s and I can personally say that they are very nice
IDK if the FT Millennium Flerken add on has reverse threads on the prop shaft. I just know that they do exist in the wild, specifically for twins. I would assume a pusher would maybe have the same reverse threaded shaft.
No the motor spins ccw as it should as viewed from the tail and has a pusher prop designed to spin cw as viewed from the nose. This prevents the nut from spinning off
