YetAnotherDave
Ok so I am a "very experienced" pilot with around 5400 ... seconds of flight time >.>
I got a racer and want to do more then 8 minute flights. I know I know, 8 is good for a racer and I should be happy.
But the truth is I am greedy. I want to fly for an hour before I need to swap batteries. I want to sit on a mountain and explore! .... I'm also near broke... SO! here is my idear (see fancy words makes me sounds smarter.. per say)
I bought a storm racing drone form helipal. I know its a knock off but I did say I was near broke.
Point is I want to know if I can pull off the legs, motors, and esc's and replace them with 15" props, 'propriate motors/esc's
With a new power source (I'm looking at building a pack with old laptop batteries or something like the Panasonic 18650b batteries)
In my mind I think its a great idea however, with my 1.5 hours of flight experience (and that's being generous) I seem
to find myself lacking the knowledge of "will it work?"
Will I need a new flight controller or will my CC3D work just fine? Can I keep the same programming in my radio or do I need a new programming set for the new arrangement?
Yes I know that an hour is a lot but if I could get 30 minutes I wold be ecstatic! If it works like it will in my mind then I will have quick release behind the esc's and swap the legs out as one motor/esc/prop/leg piece to be replaced with the other.
The main idea being I could switch between racing and extended flight in less then 20 minutes.
Help me internet! your my only hope!! (of not spending moths actually learning about the things I'm trying to do before I know if it will work)
