For Sale - RC Explorer/David Windestål Tricopter V2.5 Unbuilt
This was an RC Explorer/David Windestål Tricopter V2.5 that never got built.
All parts were sourced as recommended by David, according to the build tutorial here:
https://rcexplorer.se/projects/2011/...ricopter-v2-5/
All parts are NIP, with a couple opened for inspection only upon receipt.
Included is the following:
2 x Genuine RCE CNC Cut Tricopter V2.5 Plates
1 x HK Multi-Rotor Control Board V2.1 (Atmega168PA)
3 x KK2.0 Board w/Sonar Upgrade
4 x DT750 750kV Motors
4 x TURNIGY Plush 18amp Speed Controllers
1 x BMS-385DMAX Digital Servo (Metal Gear)
3 x Packs GWS 11x4.7 propellers (15 total)
3 x Packs Front wheel steering mounts (15 total)
1 x Huge Roll 25mm Transparent heatshrink
1 x Huge Roll 4mm heatshrink
4 x Packs Male to male servo cables (40 total)
1 x Pack M3 Hex screws.
1 x Pack M3 lock nuts
1 x Pack Scorpion Battery straps (3 total)
1 x Pack 42cm servo extension (5 total)
2 x Packs 3.5 bullet connectors (20 pairs total)
1 x Turnigy ESC Programming card
Common materials not included, and required for completion:
3 x Booms (Wood, Carbon, your choice)
4 mm carbon fiber rod
40+ of 2.5mm zip-ties
3 mm thick plywood
8 mm silicone tubing
Blue locktite
CA glue
This kit will certainly appeal to the dedicated DIYer looking for a bargain, or the hardcore Flite Test/DW Fan looking for some nostalgia.
See this link for info regarding KK2 setup.
And see this link for info on HK Control Board 2.1 setup.
$110 shipped in US. PP only please.
3 mm thick plywood
Blue locktite
CA glue
