@makattack,
The cleanflight version of TriFlight is stalled out due to some really bad CleanFlight issues that started in 1.14. There were performance problems that caused the CPU to go to 100%, and issues with the filtering that amplified rather than filtering noise out, and issues with the autoleveling routines. It was so bad, my motors were about cooked in less than 30 seconds of flight from the oscillations. There has been some talk of switching to BetaFlight based rather than CleanFlight. Watching that thread as I was beta testing TriFlight 0.6 too.
Hard to give an objective comparison between CleanFlight and dRonin versions since it's been so long since flying the Cleanflight version. But my overall impression is that the autotune in dRonin had the PIDs locked in really good compared to what I had been flying previously. There is still the typical tricopter tail waggle in places, but it did not seem bad at all when I was in the goggles. I notice it in places when looking at the DVR of the FPV video. I need to check to see if dRonin uses expo on the throttle by default. Seems like everything I run it on takes more throttle to get the same punch.
EDIT: Just checked... Default throttle curve was only going to 90%.
@PsyBorg,
This was 100% autotuned PIDs and Tailtune. I have been very impressed with the autotune routines that dRonin uses on every build I have done. LOCKED-IN with 0 effort. You can see it in the roll spins from the video. Crisp stop at the ends with no bounce. This was literally the first flight I made with it after getting a successful set of PID and Tail autotunes. I should have done some punch outs and throttle cuts to see how well it handled the torque yaw compensation. Thinking about upgrading the motors from 2000kv to something krazeeee.....
Was great to get outside, because flying in the Dome is very limiting on how much power can be used. Managed to get 10+ minutes in the air with my AWK210 in the dome and normally the battery is run down after 3-4 minutes. LOL
Cheers!
EDIT: Just went back and looked at some of my previous BabyTri videos. Definitely the best it has flown. There were some twitches before that are completely gone. Going to bump up to 2450kv from the 2100kv motors, and already fixed the linear throttle curve to go all the way to 100%. Baby is gonna be a whole lot meaner next time he goes out!
