Foamforce
I like building planes but not painting then, so I have a bunch of plain white ones. I’ve used skins before and they’re great, but there aren’t many available.
I thought to try gift wrap as a cheap and cheerful skin. I thought it turned out pretty well! In my first attempt here, I went with some goofy looking Christmas gift wrap, but there are a lot of gift wraps that would be much more appropriate. Striped gift wrap would look pretty good on planes for example.
I tried applying it two ways. The first way was the normal way. I removed the paper from the foam, cut a piece of gift wrap a little larger than the part, and used 3m Super 77 to attach it. Then trimmed the excess. That worked well but the trimming takes a bit of time.
The second way involves my needle cutter. I figured I could eliminate the trimming step by applying the gift wrap to the entire sheet before cutting it. Now that I think about it, this would work for normal scratch building as well. The result wasn’t as good as the first way because it was difficult to get an entire sheet of gift wrap to cleanly attach to the foam without wrinkling it. I think I can do better though. If I taped the gift wrap flat to the table, printed side down, apply the Super 77, and then lay the foam on top of that, I think I can avoid the wrinkles.
Anyways, here’s the result. It’s certainly not plain. 🙂
