hey guys i need some help.... i finished the glider and man i looked fantastic..... i balanced it perfectly on 25% cord..... and threw it that thing did not want to land... 25metre from a slow hand toss.... sadly i did not record any of this......
elated i picked it up turned around and threw it ... well i know it can do a figure of 9..........
turns out the weights in the nose had shifted.
but here is my problem... i am having to add 200grams of weight in the nose. which i desperately want to reduce...
so one problem i found was that the v-stab and h-stab weigh in total 50grams which means that i needed to add 100 grams of weight into the nose to counter that(the nose is half the length of the tail).
now how do i build an ultra light tail that is fairly rigid?
i can get balsa but that will only get here in a week and im kinda impatient.
Hot wire i chunk of foam.. that will be super light...
make a light frame from barbeque skewers and cover it in some laminating plastic
or use some fibre glass and make a fibre glass tail..
and advice would be much apreciated..
@Piotrsko @Crawford Bros. Aeroplanes @bracesport @thenated0g @Wildthing
