Thanks SPONZ!
I have been waiting for this Full Sized Mustang ever since you released the Mini Mustang which I found to be an easy build and looks good in flight too. I could have printed the originals but I knew your draft would be much easier to work with and worth the wait.
I appreciate that you have printed the title & layout sheets at the end of the drawing for the following reasons, which I'm sure you realize but others may not. First it syncs up the page numbers with the tile numbers making it easier to assemble the plans. Second the tile numbers also sync up with the printed page output, which is advantages for printing individual part templets. Finally print page one you get tile one, no thinking involved which is getting harder as I get older.
I would also like to commend the idea you clearly embrace which is fewer sheets per part is more important than fewer overall pages per drawing, paper is cheap. Probably like most builders, I print to 8x11 then string together the smallest subsets of sheets that I can use to make a single part templet. If a part crosses multiple rows and columns of sheets then these quilted templets can become unwheeledly and more likely to be misaligned due to printer tolerances.
Again I appreciate all your efforts as well everyone one on the Flite Test team who endeavor to make the build experience enjoyable, I know I'm hooked.
