roversgonemad
This isn't my build along plane, just priming the pump. If you are looking for a build along plane, and have little balsa experience, these little Stevens Aero planes are awesome. I built the fuselage in about 2.5 hours. It all tabs together dry, then you glue. It's very easy. If you can read the manual, you can build one of these little planes.
Edit: Just for clarity, the entire assembly doesn't tab together and glue all at once. There are sub assemblies that get glued, then they combine to make the larger parts. There's a little balsa bending too, so there are lots of little things to learn while building.
