FinalGlideAus
terrorizing squirrels
My Sunnysky motor order finally arrived today and, WOW I am impressed with these little beauties. They are going on my Titan tricopter but after seeing these I'll be buying some more for my Bat Bone and will be using the NTM's for door stops along with all the earlier Hobbyking motors I have bought recently. Why is no one on here using them? I'm guessing it's a combination of the inexperienced are just using what the others have and some don't want to pay extra for them. Well I looked at the overall cost and it's not true. Let's compare the NTM motors which used widely on multirotors (possibly because David uses them?).
An NTM here (that I have) is around $17 while the similar sized Sunnysky is around $28. But remember you need to get the accessory pack for the NTM for $2. Two of the four NTM's came with dead bearings brand new and the others have shat themselves in only a couple of hours of flight. Good quality replacement bearings here are $5 each (two for each motor). Finally I got my Sunnysky's free postage and the NTM's cost $10 postage if you don't have to order anything else from Hobbyking. So for around the same overall price you get all these benefits.
-Much better quality build and windings than the NTM's (the NTM's windings are cr&p)
-Top quality bearings that are known to last for ages (the NTM's don't even last the postage flight!!!)
-Balanced almost perfectly from the box (the NTM's are absolutely hopelessly out of balance from the box)
-Spacer bushes on the shaft to stop slop (the NTM's have none and this is one reason why they are noisy)
-Decent quality X mounts (the NTM's are only useful in bin)
I highly recommend checking them out guys. They are quite cool!!
