cyclone3350
Got bored with the Gee Bee so I need a break from balsa & doing this foam build. I originally saw this on another forum here: https://www.rcgroups.com/forums/showthread.php?1968930-BD5-Pusher I had this 90mm that I got from a swap meet & was thinking I could upscale this one to take it. I later found that a bunch of folks did do this one in a 70mm so now I know I am on to something. Took the original plans & tiled printed @ 50% the size I wanted. Laid it out on my drafting board ( yes, I'm that old @ don't do CAD yet ) & proceeded to make the changes to accommodate the EDF & retracts. The plan is to hot wire the inlet & saddle portion for the EDF to sit in & will hot wire the wings & tail as well. The main fuse structure will be the last of my 6mm depron with DTFB wrapping around that. Took a couple of days to get the wire cutting sorted out for the motor but I finally got it to where it should work. It will be 1/16" balsa sheeted for the added strength & plywood attachment insert for the motor to bolt on to. I think I will make the rest of the thrust tube with DTFB, paper removed & steamed curled. It will be 51" WS. & estimating to weigh in over 6lbs. Might be closer to 7 as this will also be an 8s power. Probably won't go with the James Bond colors from Octopussy, but will decide on that later.
