SP0NZ submitted a new resource:
Dummy Radial XL Mk.II - FREE STL: Dummy Radial XL Mk.II for FT 2814 Motor
Read more about this resource...
This dummy radial engine is designed to work with the Flite Test 2814/1100kv motor. I designed it to add semi-scale detail to your foam board model airplanes. It prints as a single piece with no supports using basic PLA filament. The dummy radial has pass-thru cooling to provide air flow over the motor and into the airframe for ESC cooling.
The dummy radial is designed to be...
