Hello Everyone,
I've got a few post on here for a FT Guinea Pig that I've been crashing all winter. Upon my last crash, I found that I had smoked a winding on one of my iPower IBM2212q 1000kv motors. Here's where my question comes in. I replaced these 2212s with some No Name 2213 935kv motors (see pic) with no name 20a escs. My iPowers had 20a Simonk escs. I'm experiencing a drastic thrust difference between the two setups. I'm using the same cheap 10x4.7 props on both and with a 3s 2200 the Ipower motors had unlimited vertical and would get away from you with 100% differential thrust. I'm having a hard time getting the 2213s to even attain flight... I don't have a spec sheet for these 2213s but the Emax equivalent has a max thrust of 860g and the iPowers are rated for 850. I don't have either of the turn numbers but I'm assuming one of a few things. Either the generic escs I have don't provide enough amperage to bring the 2213s to full potential, OR these 2213s are WAY over-rated. OR I'm expecting way too much for a 935kv motor to compare with a 1000kv motor...
I've tried different batteries, I've synced my throttle, and I've maxed out my end points for the throttle channel. I am able to get off the ground and make a few turns around the field with a 1300 4s, but I don't really want to smoke these escs or motors so I've been laying off the 14.8...
The only real difference I see between the two setups is the esc wiring (hence why i haven't just swapped the escs between the motors). The iPowers have heavy (maybe 14 ga) power wires and 3.5mm bullet connectors. The 2213s have very thin (18 or even 22ga) with TINY bullet connectors (1.5mm or 2mm). Could this possibly be part of the problem with these 2213s? Thing is, if the wiring were causing a bottleneck, I would assume the wires would get warm when in operation. Neither the wiring or the escs get warm whatsoever.
Anyway, I've rambled enough. If anyone has any ideas I'd greatly appreciate hearing about it. Thank you!
