Anyone had a go at this?
Where can you get the recordings?
Can you tie it into an electric motor control to sound realistic?- rpm sound changes, ground idle, "cammy" ground sound?
Ie: like radials miss, fart around when starting , and "hunt" under low load.
-A few vibes, and some smoke, and it would seem real!!!
Can you get tiny amps that run off lipo batteries?
I remember they used to have "op amps" which were only about an inch across.
What about speaker setup- can you just use sound holes in the fuselage, what style of speaker system?
Those floaty bluetooth ones are quite light.
How many watts? -50 watts is quite loud when you are right next to it.
