Flying wing doesnt want to stay in air
Boiii
Hello. I have a problem. i made this flying wing and it flies really weird. It oscilates really bad. What could be the problem?
Video doesn't give much help, could be on edge of stall, local wind eddies, lousy CG placement, neighborhood radio interfering or even twitchy fingers on controls. Definitely not a smooth stable flight
Hard to tell from the pictures or video. Looks like a Kf airfoil with out any kind of spar.
Maybe the wings are flexing. Maybe try a thicker airfoil. Maybe round over the leading edge of the wing.
Boiii
The wings should not flex. They are pretty stiff. I am gonna taper TE and LE after I find a design that works. Why are you recommending to use thicker airfoil. To make the wing stiffer?
Make sure your control rods, control horns, and servos are not flexing, especially the pushrods when pushing. With push rods that long, there can be quite a bit of flex. This can be difficult to diagnose, but rather easy to fix.
Boiii
Not saying that this is the problem here cause they are pulling to make the plane go up but what are the best types of fixis? Taping a bamboo scewer to the pushrod?
Boiii
Theoretically speaking if the Cg was off. Would not it make the plane pitch up? I did not use any down input in this flight
Boiii
Suggest you try it with the same amount and see what happens. You might cover the range of 1 to 3 degrees.
Just got back from another try. the reflex was about 5 degrees and it still would not want to stay in the air. there isn't thrust issue because it only weighs 220g.
L Edge
If there is not enough thrust, did you check to see if your prop is running the right direction?
...To make the wing stiffer?
Yes, stiffer & thicker airfoil may add some stability. Somethimg is flexing, could be the wings, could be the pushrods, maybe something else.
Do I understand that you can't get any altitude? Or are you just trying to stay so low?
joelspangler
Does this have a dumb receiver or some sort of stabilized flight controller? An overturned flight stabilizing system can do that. If it's a dumb receiver, check that your linkages are tight enough to not wobble - the one pic seems to show a very large hole in the control horn.
Boiii
The plane just would not climb. Unfortunately, it is beyond repairable after the last flight (It is bent in weird angles).
