Last one was 625 auw, so Im actually down 110g. Carrots make great bombs!Nice! Just ensure that the wing sits flat on the fuselage.
Great Idea! Paint the carrots and use them as bombs.
Should fly well even if a little heavy!
Have fun!
If you go profile fuselage you will not save a great deal.Hailee, how much weihht do you reckon could be saved with a profile fuse?
Time for you to publish your plans!Man, this thing works great! Did about 20min of touch n goes, kinda. Taxi, liftoff, try to land. After 20 min started to actually get a little coordination. Making this tiny trainer a pusher with landing gear is the best thjng Ive done yet.
Does seem a little underpowered on the 2s though, but well see I guess.
It might be exactly what someone is searching for!
Congratulations
Have fun!
Ideally just draw up any parts you designed and whilst I cannot find it at the moment there was a thread with a list of the various TT add ons and modifications with links to the various threads.Oh man its great. Probably have some more weight that can be shed, but it might do the trick.
How does sponz do his plans? And does he have the file for the tiny trainer? Wings and tail are 125%. Fuse is 100% jhst extended 5" in front of the leading edge. Rear of the fuse is cut where it would taper in. Powerpod slides in like it should be there. Rear wing tie down goes through the fuse where its marked and through the powerpod. The very front most leading edge of the tail is 8.5" back from the trailing edge of the wing. Twin booms are 4.25" from wing centerline and from vert stab. Can technically fit an 8" prop
