LAZY J
*CAUTION - THE BUILDER MAY (UNLIKELY) OR MAY NOT (QUITE LIKELY) KNOW WHAT HE'S DOING*
So here's my build log for the Baby Blender with a list of mods for those who may like to follow along. I will be sure to share any tips or tricks I come find along the way.
This build is my very first foam board build and a test for a list of building and finishing experiments before I go all out on the FT Seaduck that sits next in my queue.
So list of objectives for this one:
1. Build it light by removing all paper from any internal or non critical areas whilst also staying away from the hot glue gun by using PVA and Gorilla glue for the build.
2. Try both covering film (wings and tail surfaces) and spray paint (fuselage) over a polyurethane sealing coat to compare the results in appearance and weight. Also test a bunch of methods for improving the general ruggedness of the airframe.
3. Move away from the faceted FT aerofoil design with a smooth rounded aerofoil section. Also add dihedral to the lower wing for some added stability, add individual aileron servos (maybe) and rounded tips to all flying surfaces for more of a vintage look.
4. Add central cabane struts, flying wires and replace foam board wing strut assemblies with something a little more "scale".
5. Add a suitably characterful pilot figure and move the rearward servo forward. Then the forward cockpit will be faired over to make this BB into a single seater (may go with a vintage race plane look for this one).
6. Add a more scale undercarriage (gotta throw in some cool wheel pants too!) alongside a bunch of additional scale like bling that takes my fancy.
7. Fixed, non removable and lightened motor pod with ESC mounted below for a little more airflow.
So that's the goals for now.... improve flying manners, make it look great AND keep it light.... how hard can it be?!
So here we go with the Flite Test speed build kit - a lot of the kit will be replaced/chopped up but it's good to support the FT crew. Also there is a C size power pack, 9 x 4.5 prop, and a 4S 2200mah 50c lipo (will maiden on a 3S 1300mah) to throw into the mix.
