Pitch trim?
coolguyrc
I’ve got this idea to build a plane to airdrop stuff. I’m assuming anywhere between 1 to 2 pounds of cargo will fit into the 15” x 5 1/2” x 6 1/2” cargo bay. Anyone have idea of how to get the cargo out besides a steep climb. And is pitch trim enough to counter the shift in weight, or do i need some type of moving counterweight to adjust the center of mass. (P.S The blueprints shown below are my very early stage designs.)
An FT Aura 5 "should" be able to compensate in leveling mode. Best practice would be to try to balance the cargo in the plane so when it leaves, the CG doesn't change much.
coolguyrc
Thanks. I will try to balance the cargo as best I can. And maybe give a little extra range of motion to my pitch axis to keep good control with the little amount of nose heaviness i’m expecting.
