Problems getting motor running with esc and servo tester
Pictures would be a big help. Could you also provide details on what servo tester, ESC, Motor, and battery?
LB
Foamforce
Plug the black/red/white wire from your ESC into the output side of your servo tester, making sure that the black wire is on the - side. Do not plug the battery into the servo tester. Now plug the three wires from the motor into the three wires from the ESC in any order. Turn the knob on the service tester so the way counter clockwise. Lastly, plug the battery into the ESC using the main leads.
Jimdiego
Buonasera,ho un problema con esc oppure motore brushlees non so ... Stavo provando l'auto quando ad un certo punto non si è più mossa. Mi chiedevo,ci vuole un tester particolare o basta un tester normale . grazie
Can you explain in more detail exactly what's happening?
I agree with @Foamforce, the servo lead form the ESC get pugged into the servo side of the tester.
Be sure to remove the prop from the motor, you don't want it to start spinning when you are not expecting it.
