When I restarted the hobby a number of years ago now I made a series of purchases of motors with prop savers and separate prop saver attachments to suit a variety of motor shafts. They worked well and I still have a number in use BUT getting the correct "O" rings in sufficient quantity can be difficult and rather expensive. What use is it saving the prop if the "O" ring is nowhere to be found?
Well on a shopping trip, (well more of a mindless meander actually, it's a male thing!), I found myself in a disposal store in their party supplies section. Then it happened!
BALLOONS!!!
I noticed that they had a large variety of balloons, (all shapes and sizes), and at the mouth of each balloon was something that looked to be the same shape as an "O" ring. So I bought a bag of 100 for around $1 and when I got home I cut the mouth off of a balloon and used it to hold a prop onto a prop saver. It worked and quite well.
Sure the balloon mouth is a little weaker but I can easily fit 2 of them onto the prop saver and then they hold very well. Actually they hold so well and stretch far further than the original "O" ring would before splitting.
I will never need to buy an "O" ring again!
Just thought I would share this with you as it may help you if you cannot find any "O" rings locally.
Have fun!
BALLOONS!!!
Have fun!
